Post new question
Question
Reply
Honor Student
Message 1 of 3 (1,386 Views)
Pavilion not booting up - fans on high - orange LED light - power button not working to shut down
Hi,
My HP Pavillion p6510y is not booting up. I have tried searching for any help online.
The problems are as follows:
  • No boot up (no BIOS either)
  • Steady orange/amber LED
  • Power button works to initialize system startup, but will not shut it down
I have tried the following:
  • Removed ATX power from motherboard and power cord then hold down power button for 10-30 seconds
  • Removed RAM and booted up without to check for system sounds (none)
  • Did a rudimentary PSU swap (I was swapping the PSU to a 630 watt from the orginal 250 watt)
  • Used different RAM
  • Cleared CMOS
  • Left unplugged overnight
  • Looked for bulging capacitors on motherboard
Nothing has worked so far. Before this problem, I had wiped and reformatted the hard drive to factory settings. I shut it down and let it go through the installing updates. At the end (I think) it shut down and I started having this problem. All I get now is the fans on high and a steady orance/amber LED. Also, the power button does not work to shut it down. I have to either flp the power switch on the PSU or unplug the unit.
Thanks,
Henry
Reply
0
Provost
Message 2 of 3 (1,349 Views)
Re: Pavilion not booting up - fans on high - orange LED light - power button not working to shut dow
[ Edited ]
42WallabyWay, welcome to the forum.
Was one of the updates for the BIOS?  This sounds like it could be a BIOS problem.
Also, I can not find the model that you gave in HP's Support pages.
Signature:
HP TouchPad - 1.2 GHz; 1 GB memory; 32 GB storage; WebOS/CyanogenMod 11(Kit Kat)
HP Omen X; i7-6700K; 16 GB DDR4 2133; GTX 1070; 256 GB SSD M.2; Win 10 Home
HP Photosmart 7520 AIO
**Click the Thumbs Up+ to say 'Thanks' and the 'Accept as Solution' if I have solved your problem.**
Intelligence is God given; Wisdom is the sum of our mistakes!
___________________________
I am not an HP employee.
Highlighted
Honor Student
Message 3 of 3 (1,339 Views)
Thank you for the welcome, geekster.
I have no clue. There were 135 updates when I was shutting it down. That could have been one of them, but I tried clearing the CMOS by both removing the battery and moving the jumper. If you think that is the problem, I'll give it another shot.
Here is the HP page for it:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=4223474
