Question
Reply
Highlighted
Honor Student
Message 1 of 7 (476 Views)
Help: Problem with Fan Noise / p7-1011de
Hi,
I bought a p7-1011de couple months ago and everything was fine until today. While opening this morning my desktop pc, the fan noise was really loud, extremely loud. This problem persists the whole day long, although I have not noticed anything different in the PC perfomance. Quick as always.
I opened the pc, cleaned the dust, tried to locate which fan was the problematic one (I am 99% sure it's the processor's) and the problem still persists. It's not a problem of temperature either, since it does not get any less noisy when I boot the computer without it's cover. From the moment I push the button, it makes a hell of a noise.
I checked also via HP Support Assistant and Hp Update, but it did not locate any problem or the need of an bios-hardware update.
I hope someone can give me a tip, because I am really clueless and I definetely want to fix this because my appartment is pretty small Man Sad
Reply
0
Associate Dean
Message 2 of 7 (463 Views)
Re: Help: Problem with Fan Noise / p7-1011de
Pimpin2111,
Fan noise can be caused by several different problems.  I would suggest you d/l this, and report the rpms.
http://www.cpuid.com/downloads/hwmonitor/1.19-setup.exe
Causes:
1) dust build-up under the CPU fan, and in-between the heatsink fins.
2) Cracked fan mount
3) Loose fan screws, allowing fan to vibrant.
I am a volunteer. I am not an HP employee.
To say THANK YOU, press the "thumbs up symbol" to render a KUDO. Please click Accept as Solution, if your problem is solved. You can render both Solution and KUDO..
(2) HP DV7t i7 3160QM 2.3Ghz 8GB
HP m9200t E8400,Win7 Pro 32 bit. 4GB RAM, ASUS 550Ti 2GB, Rosewill 630W. 1T HD SATA 3Gb/s
Custom Asus P8P67, I7-2600k, 16GB RAM, WIN7 Pro 64bit, EVGA GTX660 2GB, 750W OCZ, 1T HD SATA 6Gb/s
Custom Asus P8Z77, I7-3770k, 16GB RAM, WIN7 Pro 64bit, EVGA GTX670 2GB, 750W OCZ, 1T HD SATA 6Gb/s
Both Customs use Rosewill Blackhawk case.
Printer -- HP OfficeJet Pro 8600 Plus
Honor Student
Message 3 of 7 (460 Views)
Hi,
these are the reports:
Hardware monitor Fintek F8000
Voltage 0 1.67 Volts [0xD1] (VIN0)
Voltage 1 1.66 Volts [0xD0] (VIN1)
Voltage 2 1.60 Volts [0xC8] (VIN2)
Temperature 0 23°C (73°F) [0x17] (TMPIN0)
Temperature 1 99°C (210°F) [0x63] (TMPIN1)
Temperature 2 20°C (68°F) [0x14] (TMPIN2)
Fan 0 4587 RPM [0x147] (FANIN0)
Fan 1 2530 RPM [0x251] (FANIN1)
Associate Dean
Message 4 of 7 (457 Views)
IT's time to call HP and get that unit replaced. Those temps and fan rpm are too extreme.
Intern
Message 5 of 7 (325 Views)
See http://h30434.www3.hp.com/t5/Other-Desktop-PC-Questions/fan-runs-full-speed-at-start-up/td-p/1525155... for more on this topic.
It appears HP service does not know what they are doing.  This defect seems common and is likely a defective LPCIO chip (this HP P7-1222 uses a Fintek F71858DG according to CPU-Z, and one of its temp sensors comes up at 99C on startup, intermitteently, causing the fans to race.
HP service is clueless despite my repeated contacts with them, and I am about to recommend to my university and to everyone I know to stop buying HP.
What more can I do when I cannot even get intelligent responses regarding a low-end model?
Intern
Message 6 of 7 (234 Views)
Problem is defective CPU.
I had same intermittent fan problem and SIW showing TMPIN1 at 99C when this occurred (which is physically impossible).  Replacing the CPU, in my case an Intel Pentium G630, cured the problem.
TMPIN1 I believe is a sensor in the CPU's "northbridge"-function area for memory control, etc.
See http://h30434.www3.hp.com/t5/Other-Desktop-PC-Questions/fan-runs-full-speed-at-start-up/m-p/2519101#... for more.
Intern
Message 7 of 7 (223 Views)
Correction.  Fan problem recurred - even after 2 motherboard swaps by HP, and a new CPU (intel boxed) put in by me.
