×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Notebooks
- hp 15 need replacement parts for screen cover and hinges
02-26-2016 12:22 PM
Not sure if this is the right forum. Dropped my HP 15t-r160 notebook and need to replace the LCD screen the plastic display cover (blue) and the side metal rails/hinges. I found the LCD screen and ordered it but I can't seem to find the exact parts I need to replace the screen cover and hinges assembly for this model. HELP! Thank in advance?
Solved! Go to Solution.
02-26-2016 12:48 PM
P. 20 of this Manual:
has an exploded diagram of the screen assembly subcomponents. Not sure if you need the frame (bezel) or the plastic lid of the laptop (enclosure) or what color it is to this would have the parts list you need.
Post back once you know the parts you need and we can help you locate them.
If this is "the Answer" please click "Accept as Solution" to help others find it.
02-26-2016 12:48 PM
02-26-2016 01:34 PM
Thanks for replying! I need the plastic cover that holds the webcam and has the 2 hinge railings with the attached hinges. I can find them but none specifically for this model. Are they all the same? The laptop is the dark blue color and I cannot find the that in blue.
Thanks for your help!
02-26-2016 02:19 PM
Hi,
What is your HP 15 ? Must be HP 15-something because HP has hundreds of HP 15 models/products.
Regards.
02-26-2016 02:52 PM - edited 02-26-2016 03:00 PM
@banhien It is a 15-r160sa as he said in his first post (sort of).
Did you look at page 20? It is an exploded diagram of the insides of the screen and lists all the parts by number. I assume you are in the US. Yes, this Manual lists the parts for your model and all models in the same series.
The part that holds the webcam could be either the screen frame or the screen enclosure so we need some help there. The parts are by color and one of the options is blue. The screen hinges and rails are the same for all non-touch models and yours is non-touch.
Hinges (left and right) For use in models without a touch screen 749655-001
Let us know about the other part you need and we can link you to that, too. Is this it?
08-03-2016 01:42 PM
You are a God! I called hp and they said "you can't fix it but we can for 200.00" how is it I can buy the part but not fix it. It won't work right now anyway cause the hinge won't let me open the lid far enough to even push the power button. I know it won't be easy but I will try anyway
Didn't find what you were looking for? Ask the community
