Question
Reply
Honor Student
Message 1 of 62 (103,731 Views)
Scroll/Num Lock and Caps Lock LED's blinking and battery not charging
I went to get my HP dv4 Pavilion laptop after work tonight to check email and i opened it up and moved around the mouse to wake it up...the lights on they keyboard all came on as if it were starting but the screen stayed black. I waited a few minutes because sometimes it's been known to take a few seconds to actually kick on...but nothing happened so I forced shutdown by holding the power button. Turned it back on and the screen came on(with a "your system didn't shut down properly error screen) but it still started, but now the Caps Lock and Scroll keys had blinking lights on the side and top, blinking together about every second. I tried tapping the buttons and nothing happened. What caused this and how can i get rid of the blinking. I've read from doing a google search that shutting down, taking the battery out and unplugging from the A/C adapter and holding the power button for 15 seconds takes care of the problem...but I would like to make sure that is safe before trying as this is a fairly new laptop(just got it at Christmas time). I'm running Windows 7 if that makes a difference.
would also like to add that I just noticed that my little batter icon says it is plugged in but not charging....it's sitting at 80%....this is a brand new ac adapter that I just got last week...so I hope it's not that.
Thank you for any help you can give me....and sorry if this isn't the right forum....it seemed to be the best fit.
Regents Professor
Message 2 of 62 (103,726 Views)
Re: Scroll/Num Lock and Caps Lock LED's blinking and battery not charging
In order to help you further, could you please provide us with more information about your computer? Please post the specific model number or the (PN - Part Number) from the white tag on your computer. This will help us locate drivers and identify correct parts for your specific model.
Make sure you've got the latest HP system BIOS installed.
Student
Message 3 of 62 (103,182 Views)
Hey, even I am getting the very same problem. Did you get some solution to this?
Thanks in advance.
Teacher
Message 4 of 62 (103,165 Views)
try removing the batt for 15-30 seconds it is safe to do it is a way of resetting called power cycling
if that doesnt work it will be a hardware error code if it stilll blinks let me know
The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. There is a pause and the pattern repeats continuously at the end of the series of blinks until the error is resolved
Top Student
Message 5 of 62 (102,296 Views)
I had the same issue just now and it looks like it resolved by simply shutting down and taking the battery out for 15-30s as was mentioned in a previous post, thanks for the advice!
Top Student
Message 6 of 62 (101,999 Views)
[ Edited ]
I am having a similar problem....
My dv4-1120US just stopped working - power and battery were in place - so, I opened it up (following the instructions in the manual) and put it back together after cleaning the inside (fan, etc.) with compressed air. After I put it back together and turned it on, the main LEDs came on - the fan turned on - but the scroll and cap light started blinking - it blinks once every sec s three times, and then pauses for three secs and then repeats ....
I removed the power, removedthe batteries, reset the machine, and even removed the cmos battery and reinstalled it, and reseated the RAM - but to no avail.
Any ideas?
My dv4-1120 US has been running hot / warm with a loud fan noise for a few mos, but recently it started turning itself off intermittently (no pattern). I wanted to clean the insides in case there was dust that was causing this issue.
Appreciate your insight.
Student
Message 7 of 62 (101,799 Views)
I had the same issue..when i open my HP Pavilion Laptop..the LED of the scroll and capslock are blinking.. i tried to get the battery for few seconds but it doesnt work.. i tried all the possible solutions posted above this topic.. but still the screen is black. I badly needed this laptop now. Anyone can help and advice me please? :smileysad:
Student
Message 8 of 62 (98,988 Views)
i am having the same problem with my hp pavilion dv4 if you leave your comp on the screen will come on but it has taken me up to four hours and it will come on by its self i have turn it on and off a few times and that work sometime
Intern
Message 9 of 62 (98,959 Views)
If its blinking 3 times, that means an error in the memory modules -- one of the easier things to fix.  Try removing the memory, and then re-placing it and see if that works.  Can also try swapping the Modules.
Intern
Message 10 of 62 (98,960 Views)
I tried taking the entire laptop apart, cleaned the dust and fuzzbal out of the fangrill, and reapplied thermal paste to the heatsink above the CPU and the Video chip (AMD Radeon).
I put it back together and it did not resolve the issue.  Mine blinks a consistent 1 blink at a time and no long pause.  I dont even know what componant is defective to replace.
