Ask questions. Help others.
The HP Community is here for you.
Post new question
Question
Reply
Note on archived topics.
This topic has been archived. Information and links in this thread may no longer be available or relevant.
If you have a question create a new topic by clicking here, or click on "Post new question" above and select the appropriate board.
Honor Student
Message 1 of 4 (4,104 Views)
Wireless Switch Problem: my wireless light is red and will not turn blue
I need help!
I have problem with wireless LAN for notebook HP Pavilion dv9005us. The WLAN touch button won't active though I move the button. In a case like that, is it a hardware problem or do I have to update the driver ?
Thanks
0
Master's Graduate
Message 2 of 4 (4,067 Views)
Re: Wireless Switch Problem: my wireless light is red and will not turn blue
That could be a hardware problem or a driver issue.
Check the device manager and see if the adapter is listed.
Honor Student
Message 3 of 4 (4,028 Views)
Thanks, I followed your advice,
I run the hard disk test and the result was:
Test Status #2 - 07 Fail
Does that mean there is no solution?
I usually manage to get it going by putting pressure on the left bottom corner of the laptop while starting it. Once the logo appears, I let go and its ok, but it doesn't always work, sometimes I have to repeat the action several times or wait for a while and then try again.
Master's Graduate
Message 4 of 4 (3,982 Views)
Replace your hdd and recovery the operating system.
