This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
Problem with port 20 on ProCurve 2910al-48G-POE (2102 Views)
Reply
Student
SimonC
Message 1 of 4 (2,102 Views)
Accepted Solution
I have recently deployed 5 x ProCurve 2910al-48G-POE switches connected to 2 x ProCurve 5412zl.  I have a problem in that port 20 does not appear to work on all 5 swicthes.  Is this a config issue?
Please use plain text.
Student
Gibo
Message 2 of 4 (1,957 Views)
Re: Problem with port 20 on ProCurve 2910al-48G-POE
Hi, I am experiencing this exact issue on TWO 2410AL-48G procurve switches. Have you managed to resolve this?
Here is some basic information on these switches.
Have deployed software version W.14.29, these are stacked using J9149A  CX4 modules.
any help will be appreciated.
Student
DNelson
Message 3 of 4 (1,857 Views)
I've had the exact same problem on two brand-new switches when updated to both the 14.27 and 14.29 firmware. Backing out to the original 14.03 firmware fixes that problem, but of course lacks all of the fixes of the new firmware.
Student
loizosko
Message 4 of 4 (1,078 Views)
we had the same problem
we upgraded to the latest version 14.38 and seems resolved.
most likely was not available when you had the problem
