- HP Support Forum Home
- Other HP Products
- Other Products
- Re: Trouble with HP Wireless TV Connect 2.0
HP Support Forums
Join in the conversation.
- Subscribe
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Highlight
- Report Inappropriate Content
04-15-2012 11:37 PM
I am unable to connect the Transmitter and the Reciever. I even got a new transmitter shipped to my by HP. But I am still getting a message saying "Please Activate Registration on Transmitter Unit" Don't know how to do that and there are no instructions anywhere to fix this. Almost ready to return this product back to HP.
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-18-2012 06:50 AM
Do you know the product number. It would help me find some info for you that may be helpful.
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-18-2012 08:19 AM
It appears that the transmitter and receiver are not paired. I think the quick start guide may have some instructions on how to add a device?
During the Adding Video source process, the on screen display will say “Please activate Registration on Transmitter Unit”, when you see that, press the button on the back of the transmitter and hold it for a 2-3 seconds or until the light goes solid.
Dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-18-2012 10:20 PM
Thanks for the advice. So now the transmitter and the receiver are paired, but now i have this problem.
What is on my current computer screen is not what is showing on the television. The television shows my wallpaper, but doesn't have any of the desktop icons, or even any of the open windows that my computer screen is showing. Is there something that I can do about that?
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-19-2012 08:35 AM
Great, glad to hear that it's paired now!
It sounds like your system is configured for an "extended desktop", where what you want is to "duplicate your display". I'm not sure of your exact system, (operating system, graphics card, etc), but at a high-level you want to go into your display settings and switch from extended desktop (treating your PC monitor plus the HDMI-out as one big display) to duplicate display (showing the same thing on both displays).
Thanks,
Dave
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-19-2012 10:50 PM
- Mark as New
- Bookmark
- Subscribe
- Highlight
07-17-2012 12:01 PM
Hi,
When I connect the different devices, on the TV this sign appears "Connected to PC adapter, Please check video source"
What does that suppose to mean and why the pictures does not want to appear on the TV?
- Mark as New
- Bookmark
- Subscribe
- Highlight
07-17-2012 12:11 PM
Hi, from your description, it sounds like the transmitter and receiver are paired (since it says it's connected to the PC adapter). In this case, it sounds like the transmitting side is not actually sending any video out of the HDMI port. Are you sure that the PC that the transmitter is connected to is configured to output video to the HDMI port?Depending upon your PC, it might have some keyboard keys that activiate the HDMI video port, or perhaps some software on the PC needs to be configured to activate the HDMI port?
Hope that this helps,
Dave
juliaizso wrote:
Hi,
- Mark as New
- Bookmark
- Subscribe
- Highlight
07-17-2012 12:26 PM
Hi Dave,
Thank you for your quick answer, I really appreciate it!
I have got Toshiba PC and will try to check somehow what you have suggested!
Julia
- Mark as New
- Bookmark
- Subscribe
- Highlight
07-19-2012 03:48 PM
Hi I have a similar problem at first everything works like a charm but then after about 1-3 minutes the screen goes black and no sound comes either. Sometimes it displays the sentence: Connected to PC adapter, please Check video source. The link lights are showing blue and it definitely is connected. But why does it cut off the transmitting the sound and picture? When you take out the transmitter for a while and plug it back in it works for a while may be 20 secs then it goes black again. does it overheat? or what.
The after a while the screen goes totally black. (probably sleep mode or similar) but there definitely is a connection but it does not send or receive the image and wont wake the receiver...
please let me know how I can fix the issue.
Gösta
