This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
Re: USB Flash Drive v210w 16 GB Write Protected AGAIN (6475 Views)
Reply
Intern
rei_vilo
Message 1 of 3 (6,490 Views)
Accepted Solution
Bonsoir,
Again, my 16 GB v210w went write protected.
Same problem as for lisbon_lion67 and soma8914
The problem appeared after I formatted it FAT32 on my Mac.
I tried to format it on XP with many USB drive utilities, but always sector is said to be =0 and an error is raised.
Is this flash drive Mac compatible?
How to change it? My dealer made one change but its policy doesn't allow a 2nd change.
Best regards,
rei_vilo wrote:
Hi!
After one week of usage, my new USB Flash Drive v210w 16 GB appears as Write Protected.
Impossible to add a new file, delete an old file, even format the whole USB Flash Drive.
I tried various procedures described on forums, as
  • My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePoliciesWriteProtect > Value Data set to 0
  • \devise\harddisk1\dr2
and normal formatting (Properties > Format) and low level formatting tools, as
but in vain.
What happened? How to resume using my USB Flash Drive normally?
I'm running a mini 311c on XP SP3.
Thank you for your help and best regards.
--- rei_vilo
Please use plain text.
Intern
rei_vilo
Message 2 of 3 (6,475 Views)
Hi!
I contacted hp support and got as an answer the name of a recovery utility Ufix.rar.
Unfortunately, this utility doesn't recognize the v210w.
hp-branded flash USB cards are manufactured by PNY.
So I went to the PNY website and dug a little.
Actually, the latest release is Ufix2v3.
Ufix-II (USB Flash Driver Format Tool)
Applicable for PNY/HP 4GB/8GB/16GB/32GB flash drive products
(This software is not applied to A.V.S. Attaché,
but applicable for AVS-II)
2.98MB
Download
It worked and restored my USB card.
Windows and Mac OS format utilities seem not to handle correctly the USB flash card correctly.
Mac OS says there's a 16 GB drive mounted on an USB support. I can unmount the volume without eject the USB connection.
hp: Please mention this solution on the FAQ!
Best regards,
--- rei_vilo
Student
hamid_123
Message 3 of 3 (5,880 Views)
special thanks for your gooooooooooooooooooood solution
I waste my time for 48 hour to find a good solution for formating my silicon usb flash disk and try all the low level format , , Hp format tool, and many other softwares without respons. but your sotware solved my problem in a few seconds .
MERCI
