This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
Re: USB Flash Drive v210w 16 GB Write Protected (76105 Views)
Reply
Intern
rei_vilo
Message 1 of 21 (76,122 Views)
Accepted Solution
Hi!
After one week of usage, my new USB Flash Drive v210w 16 GB appears as Write Protected.
Impossible to add a new file, delete an old file, even format the whole USB Flash Drive.
I tried various procedures described on forums, as
  • My Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePoliciesWriteProtect > Value Data set to 0
  • \devise\harddisk1\dr2
and normal formatting (Properties > Format) and low level formatting tools, as
but in vain.
What happened? How to resume using my USB Flash Drive normally?
I'm running a mini 311c on XP SP3.
Thank you for your help and best regards.
--- rei_vilo
Please use plain text.
Intern
rei_vilo
Message 2 of 21 (76,105 Views)
Intern
rei_vilo
Message 3 of 21 (76,078 Views)
[ Edited ]
Hi!
I get help from hp support service.
The support technician suggested me to perform a disk format test with http://panasonic.jp/support/global/cs/sd/download/sd_formatter.html.
It failed and prompted the message "Disk protected", so my USB Flash Drive was considered as dead.
So I went back to my reseller and proceeded to an exchange. The reseller wasn't surprised: according to him, big USB Flash Drives seems to be prone to this kind of malfunction.
I hope to be luckier with the new one!
--- rei_vilo
Student
psburrows
Message 4 of 21 (75,917 Views)
I too have this problem, the Flash Drive will not allow any overwriting or deletion, but fail to understand that this log is marked as "Solved" If the solution is to exchange it for another one?
Seems to me that HP have an issue here, as other 16gb flash drives I have such as Sony, Maxell, Scandisk are trouble free, now I have to go back to where I bought it and get it changed on a basis of it might happen again!
Intern
rei_vilo
Message 5 of 21 (75,705 Views)
Bonjour psburrows,
Yes, the solution is to exchange it for another one :smileyindifferent:
Warranty is two years long :smileyhappy:
--- rei_vilo
Intern
rei_vilo
Message 6 of 21 (69,772 Views)
Hi!
I contacted hp support and got as an answer the name of a recovery utility Ufix.rar.
Unfortunately, this utility doesn't recognize the v210w.
hp-branded flash USB cards are manufactured by PNY.
So I went to the PNY website and dug a little.
Actually, the latest release is Ufix2v3.
Ufix-II (USB Flash Driver Format Tool)
Applicable for PNY/HP 4GB/8GB/16GB/32GB flash drive products
(This software is not applied to A.V.S. Attaché,
but applicable for AVS-II)
2.98MB
Download
It worked and restored my USB card.
Windows and Mac OS format utilities seem not to handle correctly the USB flash card correctly.
Mac OS says there's a 16 GB drive mounted on an USB support. I can unmount the volume without eject the USB connection.
hp: Please mention this solution on the FAQ!
Best regards,
--- rei_vilo
Student
r1ez
Message 7 of 21 (66,265 Views)
Hello There,
I have the exact problem that my HP Flash Drive is write protected and nothing I can do about it, but using UFIX-II is completely solving my problem. Thanks.
Cheers,
-r1ez-
Intern
rei_vilo
Message 8 of 21 (66,160 Views)
Hi!
I'm glad it worked for you.
Please click on Kudos so the answer would be recommended!
Best regards,
--- rei_vilo
Student
Cobsen
Message 9 of 21 (59,097 Views)
The ufix repaired my device too. But I had to take a few tries, so don't panik, if it won't work immediately.
Big thanks!
Student
padluck23
Message 10 of 21 (55,509 Views)
hi same problem....pls help USB Flash Drive v210w 16 GB Write Protected!!!! i cant find where to download Ufix-II pls tel me where i can download it..?
