This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
Re: Help with HP Deskjet 6500 wireless connection (353 Views)
Reply
Top Student
awhq1
Message 1 of 3 (383 Views)
Accepted Solution
My HP Deskjet 6500 worked perfectly via my wireless network until I turned off my SSID Broadcast. Now the printer SAYS it is connected to the wireless network, but I cannot print to it. The printer does not even show up as being on the network.
There MUST be a way to configure it to connect to a wireless network witout SSID Broadcast turned on, since nobody who cares about their wireless security would leave their SSID Broadcast on all the time, right?
Please use plain text.
Provost
PrintDoc
Message 2 of 3 (353 Views)
First, disabling the SSID broadcast is not a security measure.  Freeware from the Internet can still read it.  Plus, as you have determined, your printer will not like it at all.
Read this for more info: http://blogs.zdnet.com/Ou/?p=43
________________________________________________________
Say "Thanks" by clicking the Kudos star in the post that helped you.
I am employed by HP
Top Student
awhq1
Message 3 of 3 (346 Views)
True, a determined person can find the SSID, but having SSID broadcast turned off prevents the casual snoop from finding my wireless network and trying to get into it. Or, put another way, having SSID turned on is an invitation to the casual snoop to try to get in. It certainly is not a "security" item to have it turned off, but there is no reason to have it turned on. Every other device I have has the option to connect to a wireless network with SSID turned off. I find it amazing that HP would design the printer without this option. I will turn SSID back on temporarily until I have time to run a hard wire connection to it. I will certainly keep this in mind when I shop for my next printer.
