- HP Support Forum Home
- Printers & All-In-Ones
- Networks/Wireless
- Re: My HP Officejet Pro 8500 Wireless keeps going offline.
HP Support Forums
Join in the conversation.
- Subscribe
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Highlight
- Report Inappropriate Content
03-21-2012 12:28 PM
sure...i'm not a mac guy, but the principal is the same. ask away..
Re: My HP Officiate Pro 8500 Wireless keeps going offline.
- Mark as New
- Bookmark
- Subscribe
- Highlight
03-25-2012 09:17 PM
I finally solved this.
I had a refilled cartridge (not an official expensive 940 cartridge). When i swapped it for a brand new HP 940 cartridge, everything then worked just fine.
Before I solved it, the printer didn't complain and would work for 30 minutes or so, but then would lock up.
My guess is that the printer was trying to send a communication to the PC that somehow wasn't getting through.
(Software / firmware mismatch, or anti-virus software blockage, or who knows).
It all makes me dislike HP. I don't mind buying razor blades but buying a $37.00 ink cartridge that's mostly profit leaves behind a bad customer experience and a lot of bad will.
- Mark as New
- Bookmark
- Subscribe
- Highlight
03-26-2012 07:05 AM
After 1 hr 40 mins on the phone to India the thing that solved it was a synchronized hard-reset; unplug router, shutdown computer, unplug printer... plug-in router, reboot computer, plug-in printer. Set up wireless network with the wizard, and off we go.
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-19-2012 10:57 AM
Did you ever get the original post problem fixed? I have been dealing with this for about 3 weeks and have talked to HP support a million times. Nothing seems to work. I have to shut down my printer, then it prints, but if I let it sit for a few minutes (10ish or so) and then try to print something else, it gets stuck in the print queue and instead of the normal print job name of whatever program I am printing from, it gives this:
mhtml:{608BF20D-2F93-4DB3-A9FD-93C0A4886EBB}mid://
- Mark as New
- Bookmark
- Subscribe
- Highlight
04-30-2012 10:42 AM
I have already had this printer replaced once by HP and the problem still keeps coming back for me and many others according to many posts on the web. Somebody at HP surely knows this problem exists. The tech support people on the phone the first time around were so clueless they finally gave up and replaced the printer.
But it still has to be cold powered off all the time for the printer to work, wasting tons of ink.
The firmware LRP1FN1126AR in the printer has not been updated since in a very long time.
- Static IP vs DHCP not the issue. (printer can even successfully change IP address, WEB apps keep working, yet problem does not go away without power cycle)
- wired vs wireless is not the issue.
- Firewalls not the issue.
- Power Saver Mode is not the issue.
- Hard reset only temporary gets past issue.
- Fails both installed as Bonjour and TCP/IP
The low level IP stack is fine because you can go over to the printer and select the WEB apps and they will work even while the prevailing local issue is occurring. Perhaps some help from the team that handles the APPs should help debug this.
My old HP 8100 wirelessly on the same network is never unavailable.
I have been in the computer business for 35 years and would love to work with someone at HP that actually wants to fix this. I am more interested in truly fixing this than anything else.
Or do we need to start a class action suit against HP to get this fixed?
I wish someone (level 3 type) at HP would contact me that really wants to work on this. I am sure there needs to be a fix in the firmware. I would be glad to spend time on it.
Keith
- Mark as New
- Bookmark
- Subscribe
- Highlight
05-04-2012 07:05 AM
Thanks to everyone who has responded. It's really strange. For some unknown reason, everything started to work properly again. It stopped going offline! This happened a couple of weeks back. I sent something to print and it came out right away. Same with my wife on her laptop! So, not sure what happened. I didn't change anything or add any new software. I get windows updates automatically so maybe there was a driver update or something. However, it's still working properly!
Mike
- Mark as New
- Bookmark
- Subscribe
- Highlight
10-31-2012 03:01 PM
I am having the exact same problem. Did you ever find the resolution?
- Mark as New
- Bookmark
- Subscribe
- Highlight
10-31-2012 04:58 PM
Let me know what errors you receive?
http://goo.gl/3DAkq
- Mark as New
- Bookmark
- Subscribe
- Highlight
11-01-2012 06:00 PM
A fast workaround for me has been to use the printer touchscreen to "Restore Network Defaults" which is found under the "Network" menu under the "Setup" menu (the wrench icon). Works immediately.
The problem apparently is with the IP address becoming changed. The change happens quite frequently. But I don't know why. My set-up is an ethernet of 3 comps and the printer with one a Win 7 comp and 2 being WinXP comps. I have an old Linksys Etherfast 4 port Router with DSL.
I am now trying to solve the issue by changing my setup to make the printer a "Local" (USB) printer on the WIN 7 comp and sharing it with the 2 Win XP comps but so far I can't get it to print from the first Win XP comp - even though it is the default printer on it (that's odd). I send it to the printer and it disappears completely without appearing in print cueing or anywhere.
Any ideas how to solve that one - anybody?
- Mark as New
- Bookmark
- Subscribe
- Highlight
11-01-2012 06:09 PM
When it askes for DNS information, enter in Google's DNS. Preferred DNS = 8.8.8.8 Alt DNS = 8.8.4.4
Let me know what happens.
