This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
Re: Officejet Pro 8600 Plus connection issue - HELP! (8863 Views)
Reply
Honor Student
KAESTNERR
Message 11 of 136 (8,901 Views)
Must have been timing. My connection drops as described by Honor Student, not when I change my laptop network connection.
Please use plain text.
Honor Student
sceaj
Message 12 of 136 (8,899 Views)
I think my problem is solved and it did turn out to be the router.  I replaced the Netgear firmware in the WNDR3300 with dd-wrt and the problem has occurred since (over 1 week).   So even though the problem was with the printer, the printer wasn't at fault.
Honor Student
KAESTNERR
Message 13 of 136 (8,891 Views)
Will look into my router - been quite a while since I have looked for updated firmware for it (I don't even remember what brand it is)
Thanks!
Top Student
dkreuzen
Message 14 of 136 (8,863 Views)
I am having the same problem of the computer/printer loosing connection. I have replace the router as I thought it was the problem.  All connections are hard wired. I have set a static IP on the printer thinking that it was changing and causing the problem. At this point the only thing that restores the connection is rebooting the computer.
All three of my computers are XP but only one computer is on long enough to experience the problem.
Honor Student
KAESTNERR
Message 15 of 136 (8,851 Views)
HP are you listening? I don't log off or shut down every day - I put my computer into hibernate mode. In order to access the Officejet 8600 after it drops off, I need to log off and back on again or shut down to access the 8600 again.
Teacher
prabaa
Message 16 of 136 (8,827 Views)
[ Edited ]
From our investigation into this issue, we have found a workaround that will help with this.
 Follow the steps below.
1. Please go to Hp Software->Printer Preferences->Maintenance Tasks -> Advanced Settings
2. Selects the second radio under “Show Alerts”, “Only show me ink alerts when I print”.
3. Now restart your PC to make sure setting saved.
Find the screen shot attached.
Here is a helpful support document that may also help.
Click on the BLUE KUDOS button on the left to say "Thanks"
Please mark the post that solves your problem as "Accepted Solution"
(Although I am employed by HP, I am speaking for myself and not for HP)
Honor Student
KAESTNERR
Message 17 of 136 (8,825 Views)
I think you are answering another question/problem. We're talking about a LAN attached OfficeJet 8600 that loses connectivity after a period of time. I don't see how this can have anything to do with an internet browser.
Tutor
kcgr4
Message 18 of 136 (8,811 Views)
This is not an IE issue.   I don't use IE anyway.  I just noticed that when the printer drops off the network, then IE doesn't work either.  I have to kill the HP network software then restart it.  Then IE comes back.    Sometimes I have to kill and restart the print spooler also.   HP finally contacted me and noted that they have duplicated this in their lab and are working on a fix.
For those that have had dropoff issues, have you tried the script I posted?
Honor Student
KAESTNERR
Message 19 of 136 (8,808 Views)
I just checked IE (I don't usually use IE either) - hmmm, works for me even when the 8600 is "unavailable." I don't print a lot, so I haven't used your script - just log off and back on.
Thanks for letting us know about HP working on the problem. Pls keep us posted (HP didn't contact me).
Student
Dagnyweb
Message 20 of 136 (8,756 Views)
Yes, please let us know what support tells you.  We are having the same problem!!
