This HP Community is for Customer to Customer Product Support. First Time Here? Check Out Videos on How to Search, Register, Post and More.
wireless printer will not print (3641 Views)
Reply
Student
edjarick
Message 1 of 3 (3,641 Views)
I have an Officejet  J4680, it will print a test page from the control panel, but not from my laptop. I purchased both new about 2 months ago and I have not been able to get the printer to work properly yet. I followed the instructions with the printer and it said the installation was successful. The message I get is " The job failed to print due to an error in the printing system " .  HP laptop With Windows 7 Professional, Officejet J4680 All-in-one wireless set up.
Please use plain text.
Provost
PrintDoc
Message 2 of 3 (3,630 Views)
Re: wireless printer will not print
From where did you install the software for the printer?
Try disabling you Windows Firewall and you security system's firewall.
________________________________________________________
Say "Thanks" by clicking the Kudos star in the post that helped you.
I am employed by HP
Teacher
mancy_techno
Message 3 of 3 (2,136 Views)
Hi,
During certain cases, you may have completed the physical integration perfectly.
But still you may not be able to print anything.
This can be due to the absence of a driver installed on your system.
The problem can easily be averted, if you are installing the driver corresponding to the manufacturer.
You can ensure that the version corresponds to the exact version of the printer series as well.
Set peace of mind as your highest goal,and organize your life around it.
