HP 450 G7
I have a 450G7 that won't power on with the caps lock and power are showing a white light thats constantly on even when the laptop is unplugged from the mains.
Here are some of the things I've done so far:
Removed battery and CMOS battery and done a 20 second power drain
Tried starting up without the battery in place to run off the plug
Re-sat the RAM and tried an alternative stick of RAM
Re-sat the SSD and tried an alternative SSD
Any help will be greatly appreciated.
Thanks
1 REPLY 1
If i were you i would call HP if you have warranty
it looks like a interal Failure
