Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Audio
- 5.1 Surround sound system does not work although the unit is...
01-20-2019 09:16 AM
@UZR987
Thank you for posting on the HP Support Community.
I see that your experiencing issue with 5.1 audio does not work with the HP desktop.
Don't worry as I'll be glad to help, however, to provide an accurate resolution, I need a few more details:
- When was the last time it worked fine?
- Have you made any hardware/software changes?
- Have you tried any troubleshooting steps?
- Have you tried updating the Audio driver?
While you respond to that, I recommend you to perform the following steps to isolate the issue and arrive at a fix:
Let's perform Windows Update and HP Support Assistant:
To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates.
Install updates from HP Support Assistant: Go to Download HP Support Assistant to install the tool.
- To open HP Support Assistant, double-click the HP Support Assistant icon
- Click My devices in the top menu, and then click Updates in the My PC or My notebook pane.
- Click Check for updates and messages to scan for new updates.
- Review the list of updates. Updates with a yellow information icon are recommended. Updates with a blue information icon are optional.
- Click the update name for a description, version number, and file size.
- Select the box next to any updates you want to install, and then click Download and install.
Hope this helps! Keep me posted for further assistance.
If I have helped you resolve the issue, feel free to give me a virtual high-five by clicking the 'Thumbs Up' icon below, Followed by clicking on "Accept as solution" from the drop-down menu on the upper right corner, Thank you for posting in the HP Support Community. Have a great day!
ECHO_LAKE
I am an HP Employee
