Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Hardware and Upgrade Questions
- Omen X 900 series water cooling fan speed
03-10-2019 10:15 AM
Tried to search, even tried to contact HP, but didnt even respond to me... Does anyone know that actual RPM of the fan installed on the water cooling that comes with the Omen X 900 series? (900-101np)
Was thinking of buying a RGB fan to replace it (specifically the Jet flow of Cooler Master), but if the RPM is higher than its pointless.
Solved! Go to Solution.
03-10-2019 10:53 AM
Welcome to the HP Support Community @Correia
Sorry but I do not have a solution but more of a question.
In your BIOS are the fan speeds adjustable or is it just a notice of the static speed???
Thanks for any reply.
REO
03-10-2019 10:53 AM
REO
