cancel
Showing results for
Search instead for
Did you mean:
JoelFerriday
New member
2 0 0 0
Message 1 of 2
473
Flag Post
The power cable for my z840 Air Shroud/ Cooling Unit has broken.
HP z840
As you can see in the attached image, the power cable for my Air Shroud/ Cooling unit is broken. I'm looking to find out what the ID for the power cable is? I can find the ID for the unit itself (642166-002) however would ideally rather replace the cable than the entire unit.
1 REPLY 1
DGroves
Level 11
4,701 4,675 443 994
Message 2 of 2
Flag Post
workstation related questions/issues are best placed in the workstation specific forum
https://h30434.www3.hp.com/t5/Business-PCs-Workstations-and-Point-of-Sale-Systems/bd-p/Business-PC-W...
the z840 power cable harness is not available as a separate item from HP you can however repair the existing one using
a quality silicone rubber ADHESIVE applied at the base of the broken connector should fix the broken pin. for proper pin spacing create a spacer of the proper size at the top so the broken pin is placed in the proper position. (you can use any of the existing pins to make/check the spacer size) the spacer only needs to fill a small space between the pins at the top then take some tape and use it to hold the pin in position while the adhesive sets
https://www.amazon.com/Silicone-Adhesives-Plastic-Sealants-Lubricants/s?keywords=Silicone+Adhesives&...
the shroud is the same for the z820/z840 which will increase your chances of locating a used on off ebay if you decide to do this route instead
Was this reply helpful? Yes No
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
