Ask questions. Help others.
The HP Community is here for you.
Post new question
Question
Reply
Note on archived topics.
This topic has been archived. Information and links in this thread may no longer be available or relevant.
If you have a question create a new topic by clicking here, or click on "Post new question" above and select the appropriate board.
Top Student
Message 1 of 12 (549 Views)
Need help upgrading computer parts trying to add power supply and graphics card
[ Edited ]
i have the hp pavilion p6-2133w pc and i want a better graphics card,  to do that i know i need stronger watt usage.. i want to be able to run games like skyrim, on full quality any type of help would be greatly appreciated !
My specs are posted in the link below. again thank you !
http://support.hp.com/us-en/document/c03183981
0 Kudos
Top Student
Message 2 of 12 (534 Views)
Re: Need help upgrading computer parts trying to add power supply and graphics card
any advice would be nice >.<
Provost
Message 3 of 12 (531 Views)
In order to answer your question, you need to choose a graphics card. Then select the PSU.
1) Any highend PCIE 16 graphics card will occupy to slots.
Skyrim specs and requirements with examples:
http://www.bethblog.com/2011/10/25/skyrim-system-requirements-announced/
card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130652
more info on card: http://www.evga.com/products/pdf/02G-P3-1559.pdf
Comparing 550ti to the HD4890 http://www.hwcompare.com/9752/geforce-gtx-550-ti-vs-radeon-hd-4890-2gb/
This system is feedback driven thru Solution and Kudo flags. It's the only means of knowing if you have been served.
Please click Accept as Solution, if your problem is solved. To say THANK YOU, press the "thumbs up symbol" to render a KUDO. You can render both Solution and KUDO..
Loaner: Envy Omen Windows 10 Pro 64 bit 4th Gen Intel(R) Core(TM) i7-7700HQ + NVIDIA GeForce GTX 1070M 8GB Discrete Graphics (16GB RAM) 512GB m.2 SSD
HP Envy 8 5010 Tablet
(2) HP DV7t i7 3160QM 2.3Ghz 8GB
HP m9200t E8400,Win7 Pro, 4GB RAM, ASUS 550Ti 2GB, Rosewill 630W. 1T HD
Custom Asus Z97D, I7-4790k, 16GB RAM, WIN10 Pro 64bit, ZOTAC GTX1080 8GB, 500GB HD SSD, Asus PB287 4k monitor, Rosewill Blackhawk case and OCZ 750W.
Printer -- HP OfficeJet Pro 8620
Top Student
Message 4 of 12 (528 Views)
thank you very much Smiley Surprised now i got an idea of the graphics card.. any idea on a good power supply ?
Top Student
Message 5 of 12 (526 Views)
sorry to doubble post but i forgot to add idk what powersupply would fit i wanted atleast 550w im sure that info would help you help me lol sorry still learning >.<
Highlighted
Top Student
Message 6 of 12 (517 Views)
bump
Top Student
Message 7 of 12 (494 Views)
i was able to get the one in the link to fit after removing the cd-rom drive (which not sure if that's a feasible option) :
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220653&CatId=2533
Provost
Message 8 of 12 (490 Views)
The Corsair CX500 and CX600 are highly recommended and forum favorites. Additional, they are only slightly bigger than the stock HP units and fit without issue.
Frank
Frank
***** Please click the "White Kudos" Thumbs Up to say THANKS for helping *****
***** Please click the "Accept As Solution" on my post, if my help solved your issue *****
***** This is a user supported forum. I am a volunteer and I don't work for HP *****
HP a1632x - Windows 7, 4GB RAM, AMD Radeon HD 6450
HP p6130y - Windows 7, 8GB RAM, AMD Radeon HD 6450
HP p6320y - Windows 7, 8GB RAM, NVIDIA GT 240
HP p7-1026 - Windows 7, 6GB RAM, AMD Radeon HD 6450
HP p6787c - Windows 7, 8GB RAM, NVIDIA GT 240
HP ENVY x360 m6-w103dx - Windows 10, 8GB RAM, Intel HD 520
Top Student
Message 9 of 12 (488 Views)
i know corsair makes great psu's, but both units fans blow into the case as opposed to out the rear of the case.  The pci clots on this particular computer are directly below the psu, wouldn't this prevent a potential overheating issue with a video card?
I'm having a similar issue myself, I'm not happy with the coolmax psu (mainly because I don't trust the brand), but I am trying to steer clear of a psu that vents into the case, let alone directly onto the video card.
Top Student
Message 10 of 12 (484 Views)
i guess my question is would the psu blowing hot air onto a video card make that much of a difference?  I have this same computer and was lerely of anything venting into the case, especially onto the pci slots.  Any pc I've had or built in the past has always had the pci slots near the bottom of the tower.
