×InformationFix Windows 10 Update Issues
Resolve Windows 10 related issues for your HP computers or printers by HP Windows 10 Support Center
- HP Community
- Archived Topics
- Desktops (Archived)
- Pavilion elite power supply light on, won't power up
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
07-24-2016 11:06 AM
07-24-2016 11:13 AM - edited 07-24-2016 11:16 AM
As you did not mention any message or display on the screen, I would use this tutorial for a step by step diagnostic. It also helps to remove the side panel, and visually watch the CPU and rear case fan movement(s). As you press the power button, pay attention to the fans. Also does the Power Supply LED stay ON? Or did it go OUT when you pressed the power button?
HP Envy 8 5010 Tablet
(2) HP DV7t i7 3160QM 2.3Ghz 8GB
Printer -- HP OfficeJet Pro 8620 Legal
Custom Asus Z97D, I7-4790k, 16GB RAM, WIN10 Pro 64bit, ZOTAC GTX1080 AMP Extreme 3 fan 8GB RAM, 500GB SSD, Asus PB287 4k monitor, Rosewill Blackhawk case and 750W OCZ PSU.
07-24-2016 11:19 AM
07-24-2016 11:47 AM
I would go back to the tutorial, and unplug the 20/24 pin motherboard and the 4 pin CPU motherboard plugs. The I would do the "Testing the power supply separately from the system" with the suggested paper clip. I suspect the PSU took a hit recently when you were away. This is possible if the power was still applied to the PSU.
07-24-2016 12:08 PM
The next step is to re-seat the memory (RAM) modules.
07-25-2016 08:23 AM
Do you have access to a spare power (PSU) supply?
It's perplexing that the PSU fan will spin when it's jumpered (as a test option), but the CPU and rear case fans show no movement when the PSU connections are applied.
07-25-2016 05:37 PM
Didn't find what you were looking for? Ask the community
