    Check documents on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
Are you having hardware issues? Click here for tips and tricks.
Hp Pavilion Gaming 15-EC0006NT
Hi everyone.
I have sound quality issue with my audio jack. When I put my headphone in it, sound quality annoys me. Music sounds like 128kbps.
My headphone works quite good with my smartphone (Redmi Note 8). I know that my notebook's sound output is better than my smartphone. I've tried many times.
I guess problem stems from audio driver. I reinstalled already but it didn't help.
Here you can see my device manager. I don't know it's normal or not.Ek Açıklama 2020-02-14 174752.png
I can't see Realtek or B&O Audio control in programs section. But it's already installed.
My notebook's model: HP Pavilion Gaming 15-EC0006NT
1 REPLY 1
@forcas
Welcome to HP support community.
Step 1: Restart the computer
Step 2: Use the troubleshooting tool in Windows
Step 3: Test external speakers or headphones
Step 4: Set the default audio device
Step 5: Restoring or updating the audio driver
Step 6: Perform a hard reset
The best way to resolve the issue is to follow the suggestions of the HP Guided Troubleshooter:
Click here to access it (simply select your description of the issue from the bottom of the screen to gain access to the next set of steps that should resolve your concern).
I hope that helps.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
