HP Envy x360 laptop - no input or output sound.  I've tried lots of things to try to sort this out, including:
Realtek High-Definition (HD) Audio Driver installed/updated
Audio Diagnostics say:
-  No speakers found' (Hardware problem detected)
-  No microphones found ("  "  ")
Realtek(R) Audio Properties says 'Device not started ....'
Event viewer says:  MS-Windows-Kernel-PnP Event 411
Skype is one example of where I can't hear the person I'm talking to and they can't hear me.
Very frustrating I can't solve the issue after 10+ hours trying everything suggested on MS site and HP site.
It might be an issue created when I upgraded to Windows 11 in November?
Or I have inadvertently ticked/unticked a box somewhere?
Below are the results of some of the checks I have made
-  Realtek(R) Audio Properties:  - shows the Speakers are indeed installed and Drivers updated:
-  HP Audio Check - Diagnostics:  says:
    -  'No speakers found (Hardware problem detected)'
    -  'No microphones found (Hardware problem detected):
How do I solve the 'hardware problems detected'?  I have carried out checks, but same message keeps appearing
-  In the 'Event Viewer' results:
    -  Several occurrences of the same Error message have appeared in the 'Device Manager - Realtek(R) Audio' window over the last few days:
    Event source:  Microsoft-Windows-Kernel-PnP;  Event ID 411
    Q:  What is 'Event ID 411' and how do I sort it out?
Any suggestions how to resolve the sound issue would be much appreciated.  Thanks in advance.
