cancel
Showing results for
Search instead for
Did you mean:
dalejg001
Level 1
3 0 0 0
Message 1 of 2
107
Flag Post
Will Not Power On White Led light by charger port on
Hp pavilion 15-ab288sa
My laptop will not turn on. When I plug it in I get the white led light by the charger port come on and stays on solid. When I press the power on button, the light goes off but the nothing happens.
I have tried a hard reset by removing battery and un plugging then holding down power button and mute button for 30 secs.
The only thing I have changed on the laptop is replacing the battery a couple of weeks ago.
Would really like to repair the laptop!
Thanks in advance for any help or suggestions.
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
2,157 2,157 99 175
Message 2 of 2
50
Flag Post
@dalejg001 Welcome to HP Community!
I understand that the laptop will not power on.
As you have stated that you have performed the hard reset and battery replacement. The issue with the hardware part.
I would suggest you contact our Phone support. They will help you.
Here is how you can get in touch with phone support.
1)Click on this link - www.hp.com/contacthp/
2)Select the product type.
3)Enter the serial number of your device or select let HP detect your product option.
4)Select the country from the drop-down.
5)You should see the HP phone support number or Chat option listed.
Keep us posted,
If you would like to thank us for our efforts to help you,
Give us a virtual high-five by clicking the 'Thumbs Up' icon below, followed by clicking on the "Accept as solution" on this post,
Have a great day!
Reply
0 Kudos
