    Windows update impacting certain printer icons and names. Microsoft is working on a solution.
    Click here to learn more
We have new content about Hotkey issue, Click here to check it out!
Common problems for Battery
OMEN 15-008nb
This is the model of my laptop: OMEN 15-008nb
Found parts for associated model of OMEN 15-008tx which is in the parts store (https://support.hp.com/us-en/product/omen-by-hp-15-ax000-laptop-pc/10862325/model/11612715/manuals).
But when I check the battery of the tx-version: 3-cell lithium-ion (Li-Ion), 3.61Ah, 41Wh (BI03041XL-PR)    (https://parts.hp.com/hpparts/Search_Results.aspx?mscssid=7DF82A6B757445B79BFD3313DE2BCD87&SearchIn=P...)
it is different from what I found on the page of my laptop: 3-cels, 61,5-WHr lithium-ion (https://support.hp.com/be-nl/document/c05323348#AbT0 ).
Any help much appreciated!!
See the following link for replacement battery sourcing. Chose one that has a one year warranty.
https://www.google.com/search?q=15-ax008nb+replacement+battery&oq=15-ax008nb+replacement+battery&aqs...
I see that you are located in Belgium. Here in the Netherlands it is quite easy to find a replacement compatible battery at a good price. I see one for €40,32 at this link.
Remove and replace videos. Click on the Battery link in the left hand column.
http://h20574.www2.hp.com/results.htm?SID=10862325&MEID=56302E24-377B-429D-AE4F-1D654C0CF807
I am a volunteer forum member, not an HP employee. If my suggestion solved your issue, don't forget to mark that post as the accepted solution. If you want to say thanks, click on the Yes button next to the "was this reply helpful?"
3 REPLIES 3
@GoldenInsight
HP  OMEN 15-008nb is an invalid product, what is it EXACTLY ?  Please use the following instructions to find out the model/product of your machine:
    https://support.hp.com/us-en/document/c03754824
Please do NOT post its Serial number (s/n).
Regards.
BH
Thank you for your response!
I used this guide already to successfully find the model of my laptop.
As you can see in my first post, there is also a page on the hp website that has info about this model (https://support.hp.com/be-nl/document/c05323348#AbT0 ), so it does exist.
I hope a solution can be found.
Kind regards
Jeroen
