cancel
Showing results for
Search instead for
Did you mean:
GoldenInsight
New member
3 1 0 0
Message 1 of 4
121
Flag Post
Solved!
Laptop not found in parts store, which replacement battery to buy?
OMEN 15-008nb
This is the model of my laptop: OMEN 15-008nb
Found parts for associated model of OMEN 15-008tx which is in the parts store (https://support.hp.com/us-en/product/omen-by-hp-15-ax000-laptop-pc/10862325/model/11612715/manuals).
But when I check the battery of the tx-version: 3-cell lithium-ion (Li-Ion), 3.61Ah, 41Wh (BI03041XL-PR)    (https://parts.hp.com/hpparts/Search_Results.aspx?mscssid=7DF82A6B757445B79BFD3313DE2BCD87&SearchIn=P...)
it is different from what I found on the page of my laptop: 3-cels, 61,5-WHr lithium-ion (https://support.hp.com/be-nl/document/c05323348#AbT0 ).
Any help much appreciated!!
3 REPLIES 3
Level 19
Level 19
78,188 77,596 9,541 20,653
Message 2 of 4
106
Flag Post
Solved!
@GoldenInsight
HP  OMEN 15-008nb is an invalid product, what is it EXACTLY ?  Please use the following instructions to find out the model/product of your machine:
    https://support.hp.com/us-en/document/c03754824
Please do NOT post its Serial number (s/n).
Regards.
BH
Reply
0 Kudos
Highlighted
GoldenInsight
New member
3 1 0 0
Message 3 of 4
93
Flag Post
Solved!
Thank you for your response!
I used this guide already to successfully find the model of my laptop.
As you can see in my first post, there is also a page on the hp website that has info about this model (https://support.hp.com/be-nl/document/c05323348#AbT0 ), so it does exist.
I hope a solution can be found.
Kind regards
Jeroen
Reply
0 Kudos
Level 17
Level 17
45,054 40,720 4,409 11,462
Message 4 of 4
88
Flag Post
Solved!
See the following link for replacement battery sourcing. Chose one that has a one year warranty.
https://www.google.com/search?q=15-ax008nb+replacement+battery&oq=15-ax008nb+replacement+battery&aqs...
I see that you are located in Belgium. Here in the Netherlands it is quite easy to find a replacement compatible battery at a good price. I see one for €40,32 at this link.
Remove and replace videos. Click on the Battery link in the left hand column.
http://h20574.www2.hp.com/results.htm?SID=10862325&MEID=56302E24-377B-429D-AE4F-1D654C0CF807
Post any other questions you have in your thread.
Please accept as solution if this is the info you needed.
Take a moment of your time, as we volunteers have given you some of ours in trying to help you resolve your issue, to return to your thread to let us know if we helped you or not.
