cancel
GoldenInsight Honor Student
Honor Student
3 1 0 0
Message 1 of 4
106
Flag Post
Solved!
Laptop not found in parts store, which replacement battery to buy?
OMEN 15-008nb
This is the model of my laptop: OMEN 15-008nb
Found parts for associated model of OMEN 15-008tx which is in the parts store (https://support.hp.com/us-en/product/omen-by-hp-15-ax000-laptop-pc/10862325/model/11612715/manuals).
But when I check the battery of the tx-version: 3-cell lithium-ion (Li-Ion), 3.61Ah, 41Wh (BI03041XL-PR)    (https://parts.hp.com/hpparts/Search_Results.aspx?mscssid=7DF82A6B757445B79BFD3313DE2BCD87&SearchIn=P...)
it is different from what I found on the page of my laptop: 3-cels, 61,5-WHr lithium-ion (https://support.hp.com/be-nl/document/c05323348#AbT0 ).
Any help much appreciated!!
3 REPLIES 3
Provost Provost
Provost
77,436 76,848 9,434 20,414
Message 2 of 4
91
Flag Post
Solved!
@GoldenInsight
HP  OMEN 15-008nb is an invalid product, what is it EXACTLY ?  Please use the following instructions to find out the model/product of your machine:
    https://support.hp.com/us-en/document/c03754824
Please do NOT post its Serial number (s/n).
Regards.
BH
Reply
0 Kudos
Honor Student
3 1 0 0
Message 3 of 4
78
Flag Post
Solved!
Thank you for your response!
I used this guide already to successfully find the model of my laptop.
As you can see in my first post, there is also a page on the hp website that has info about this model (https://support.hp.com/be-nl/document/c05323348#AbT0 ), so it does exist.
I hope a solution can be found.
Kind regards
Jeroen
Reply
0 Kudos
Provost Provost
Provost
44,986 40,662 4,399 11,428
Message 4 of 4
73
Flag Post
Solved!
See the following link for replacement battery sourcing. Chose one that has a one year warranty.
https://www.google.com/search?q=15-ax008nb+replacement+battery&oq=15-ax008nb+replacement+battery&aqs...
I see that you are located in Belgium. Here in the Netherlands it is quite easy to find a replacement compatible battery at a good price. I see one for €40,32 at this link.
Remove and replace videos. Click on the Battery link in the left hand column.
http://h20574.www2.hp.com/results.htm?SID=10862325&MEID=56302E24-377B-429D-AE4F-1D654C0CF807
If you really want to say thanks, click on the Thumbs up icon .
If your problem is solved or question answered by my post, please click the Accepted Solution button in that post.
