HP Pavilion Gaming Notebook - 15-ak052nm (ENERGY STAR)
Hi everyone, my Gaming notebook is not used much, but its 8 ys old now and it seems the simple cooling fan nowhere to be found in this planet. I dislike to trash the device with only one simple part to change. So, kindly I ask if anyone knows how and where to get a right part, original one not the Chinese copy from US for 50 USD, part number 833139-001. I tried in my country, no luck, Amazon, e-bay & other selling sometimes another fan under this part number.
Thanks
Ivana
2 REPLIES 2
@Ivana_FN
HP does NOT stock that spare part
           https://partsurfer.hp.com/partsurfer?searchtext=833139-001
You can use part # to search elsewhere including eBay for example
          https://www.ebay.com/itm/194837913428
Regards.
BH
Dear Banhien,
I appreciate your help but partsurfer did not come with one single item found, plus the search tool is so outdated (there are countries on the list that do not exist from 34 ys ago e.g Yougoslavia). I have searched e-bay  too, and the link you sent the cooling fan, even though it holds the right part number, the position of holes are somewhat different.
My point is to ask HP when do they stop producing spare parts, my laptop is only 8 ys old... and would work just fine if I could find the part. Also it was expensive machine just to put it away...
Thanks for your help
I.
