cancel
Showing results for
Search instead for
Did you mean:
ArchivedThis topic has been archived. Information and links in this thread may no longer be available or relevant. If you have a question create a new topic by clicking here and select the appropriate board.
chetan123
New member
2 0 0 0
Message 1 of 2
110
Flag Post
wireless lan problem help me fix it as u said my hardware id for network controller is given below
natebook
Microsoft Windows 8 (64-bit)
PCI\VEN_10EC&DEV_B723&SUBSYS_804C103C&REV_00
0 Kudos
1 REPLY 1
Paul_Tikkanen
Level 21
Level 21
129,149 119,326 19,487 29,781
Message 2 of 2
Flag Post
Hi:
There are no W8 drivers from anywhere on the planet for that model wifi card.
If you want to use the wifi card, your only option will be to connect via ethernet cable or USB wireless adapter, do the required updates to W8, so you can get the free upgrade to W8.1, and then you can use these W8.1 wireless and bluetooth drivers.
This package contains the driver installation package for the Realtek RTL8723BE/RTL8188EE wireless LAN Controller in the supported notebook models running a supported operating system.
http://ftp.hp.com/pub/softpaq/sp79001-79500/sp79095.exe
This package contains the driver installation package for the Realtek bluetooth in the supported notebook/laptop models and operating systems.
http://ftp.hp.com/pub/softpaq/sp78501-79000/sp78623.exe
If you need the W8 ethernet driver, download, unzip and run the setup application from the 2nd file listed at the link below...
http://www.realtek.com.tw/Downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=7&Level=5&Conn=4&DownTy...
0 Kudos
