Windows 11 Support Center. -
- HP Community
- Printers
- Printer Ink Cartridges & Print Quality
- 7301 smart tank replacement parts needed periodically?
1 REPLY 1
04-18-2024 01:46 AM
No, the printheads on smart tank printers don't need to be replaced periodically. You only need to replace them if the print quality is not acceptable, or in a case of failure.
The ink bottle's prices are probably the same, you will hardly find a big difference in prices, Don't stock ink, buy fresh ink when needed.
Ask the community
