If you're having print quality issues Click here for more tips!
Hey, this HP printer Color Laser 150nw  started recently printing with flaws. There is a second shadowy print on the same paper, but divived. Part of it is on the one side the other is on the other side. Plus there is this line in the middle. See the image please, its kinda hard for me to describe. If the image on the paper is bigger, then it gets really bad, obviously. I have alternate toners for HP printers - W2071A, W2072A and W2073A.Obrázek WhatsApp, 2024-09-02 v 22.44.03_56b2fe12.jpg
1 REPLY 1
Hi @JHerman1,
Thank you for posting your query, I will be glad to assist you.
I see that you are facing an issue with print quality on your Printer.
A) Please follow the steps below to perform a power drain.
1) Take out the cartridges
2) Unplug the power cord from the printer & wall.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the printer and wall, ensure the printer is plugged into the wall & not into a surge protector.
5) Insert the cartridges back into the printer.
Remove the cartridges > Unplug the power cord > Wait for 30 seconds > Plug the power cord back in > Insert the cartridges
B) Kindly refer to the steps on this link to update the printer firmware and let me know if that resolves the issue.
C) Refer to the steps on this link to further troubleshoot.
D) If the issue still persists, refer to the steps on this link to restore factory defaults and let me know if that resolves the issue.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
