If you're having print quality issues Click here for more tips!
I just replaced the cyan cartridge on my HP Office Jet Pro 9018.  The cartridge was recognized as genuine and new and moments later I saw a message I've never seen before saying that there is a problem with the supply system.  I rebooted the printer, then I reset the printer to factory resets.  I returned the new cartridge to the store and get another package of cartridges.  I replaced all three cartridges this time and two of them are throwing the same error:  Supply System problem.  Is there a solution?  I'm running iOS 15.1
1 REPLY 1
Hi @drrkeith,
Welcome to the HP Support Community!
Thanks for reaching out about your query regarding your printer!
We're thrilled to have the opportunity to assist you and provide a solution.
Try these steps:
Check Cartridge Installation:
  • Ensure that all cartridges are installed correctly. They should click into place easily without needing excessive force.
  • Verify that the colored labels on the cartridges match the labels on the printer's slots.
Clean Cartridge Contacts:
  • Power off the printer and unplug it from the power source.
  • Remove all cartridges and gently clean the cartridge contacts with a dry, lint-free cloth.
  • Clean the contacts inside the printer where the cartridges connect.
Use Genuine HP Cartridges:
  • Confirm that you are using genuine HP cartridges. Non-HP or refilled cartridges can sometimes cause compatibility issues.
  • If unsure, check the packaging or consult HP support to confirm their authenticity.
Check for Firmware Updates:
  • Ensure your printer's firmware is up to date. Sometimes firmware updates can fix supply system errors.
  • You can find the latest firmware on the HP Software and Driver Downloads page.
Reset Printer Again:
  • Perform a factory reset again if necessary:
    • From the printer's control panel, go to Settings > Printer Maintenance > Restore > Restore Factory Defaults.
    • After the reset, try re-inserting the cartridges.
I hope this helps.
I'm glad I could help! 😊 If this resolved your issue, please mark it as "Accepted Solution" and click "Yes" on "Was this reply helpful?" Your feedback not only keeps us going but also helps others find the solution faster! 👍
Take care and have an amazing day ahead! 🚀
Best regards,
Kuroi_Kenshi
I am an HP Employee
