cancel
Showing results for
Search instead for
Did you mean:
Common problems for INSTANT INK, HP+ PLANS: INK AND TONER
We would like to share some of the most frequently asked questions about Instant Ink. Check out this link: HP INSTANT INK, HP+ PLANS: INK AND TONER. .
dock1457
New member
1 0 0 0
Message 1 of 2
158
Flag Post
printer failure - problem with printer or ink system
hp officejet pro 8600 plus
Other
PRINTER FAILURE - THERE IS SA PROBLEM WITH THE PRINTER INK SYSTEM. TURN PRINTER OFF . THEN ON.IF PROBLEM PERSIST CONTACT HP
1 REPLY 1
sandytechy20
HP Support Agent
HP Support Agent
27,972 27,816 1,519 1,609
Message 2 of 2
Flag Post
@dock1457
Welcome to the HP community.
I understand that you are getting printer failure errors, don't worry though as I have a few steps to determine the issue and find a solution as well.
Reset the printer.
  1. Turn the printer on, if it is not already on.
  3. With the printer turned on, disconnect the power cord from the rear of the printer.
  4. Unplug the power cord from the wall outlet.
  5. Wait at least 60 seconds.
  6. Plug the power cord back into the wall outlet.
       NOTE:
    HP recommends connecting the printer power cord directly to the wall outlet.
  7. Reconnect the power cord to the rear of the printer.
  8. Turn on the printer.
Update the printer firmware.
  1. From the home screen on the printer control panel, touch the ePrint icon ().
  2. Wait for the printer to connect to the ePrint server. The ePrint status displays.
  3. Touch Settings on the bottom left corner of the screen.
  4. Touch Printer Update, and then touch Check for Update Now.
Remove and reinsert the printhead three times.
Click here and refer to the document to perform the above steps.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Let me know how it goes.
Cheers.
Sandytechy20
I am an HP Employee
Was this reply helpful? Yes No
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
