cancel
Showing results for
Search instead for
Did you mean:
    Check documents and videos on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
anthotcool
New member
1 0 0 0
Message 1 of 1
106
Flag Post
Alignment problem; and HP smart won't recognize status
Deskjet F4480
Hi all,
Printing issue with out Deskjet F4480. When I try to print in black, it doubly prints the text line about 1cm above itself. I've wanted to try realigning cartridge, but when I open HP Smart, it says the Printer status is unknown, and Print Quality Tools option is unselectable. Reinstalling the driver hasn't worked.
A- Does this sound like an alignment issue? Taking out the cartridge and putting it back in >10 times didn't start the auto alignment page
B- Is there a way to manually go through the alignment process outside of HP Smart?
C-  Are there other suggestions to get HP smart to recognize the printer?
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
