cancel
Showing results for
Search instead for
Did you mean:
Common problems for INSTANT INK, HP+ PLANS: INK AND TONER
We would like to share some of the most frequently asked questions about Instant Ink. Check out this link: HP INSTANT INK, HP+ PLANS: INK AND TONER. .
rub1
New member
1 0 0 0
Message 1 of 1
34
Flag Post
Flip long edge/short edge problem
HP Envy Photo 6200 All-in-one
Hi, my printer does not print double sided with "flip long edge", it only prints with flip short edge no matter what setting I choose, both directly from windows 10 and from the HP Smart app on Windows 10. It seems like this is an old problem. Please do not suggest that I uninstall and re-install/download stuff. You have had this problem for years, please fix it at the source. How hard can it be to make it work with the driver that Windows automatically gives me!
HP Envy Photo 6200 does not print double sided correctly fro... - HP Support Community - 7231924
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
