cancel
Showing results for
Search instead for
Did you mean:
    Fix HP Printer issue in macOS
    A [software component] will damage your computer message displays when printing or while installing - Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Note for common printer problems
Customers receiving the"will damage your computer" message along with others like "unable to access cups/tmp" or "'@%' cannot be opened" need to update their version of the macOS. Please check this article for more information: HP Printers - A [software component] will damage your computer message displays when printing or while installing (macOS) .
Highlighted
New member
2 1 0 0
Message 1 of 3
106
Flag Post
HP 4729 Printer - No Display - Ink and Paper lights are Red
HP DeskJet Ink Advantage Ultra 4729 All-in-One Printer
macOS 10.15 Catalina
My printer was working fine and I had just printed a page. Within 5 minutes, the display went away and now I see two lights in amber color. The paper and ink lights.
The printer is no longer getting detected by HP Smart App. All printer jobs are stuck. Printer is no longer being shown on
Direct wi-fi. Even USB connection to printer is not able to print any page.
Here's what I have done so far:
1. Restarted the printer 10 times
2. Removed power cord and USB Cord and restarted the printer after waiting 2 minutes.
3. Removed Ink Cartridges and restarted Printer after waiting 2 minutes.
What shall I do?
2 REPLIES 2
Highlighted
HP Support Agent
HP Support Agent
7,344 7,310 471 524
Message 2 of 3
Flag Post
Hi @keshavx,
I'd like to help with the printer issue!
Step 1: Make sure the ink cartridges are compatible
Before you begin, make sure the ink cartridges are compatible with your printer.
  • If the ink cartridges are compatible, continue with the steps in this document.
  • If the ink cartridges are not compatible, continue to the step to replace the ink cartridge.
Step 2: Remove, inspect, and then reseat the ink cartridges
The printer might display an error if the ink cartridges are not correctly installed.
NOTE:
HP cannot guarantee the quality of remanufactured or refilled ink cartridges. Use genuine HP ink cartridges for good print quality.
  1. If the printer is off, press the Power button to turn on the printer.
  2. Open the exterior door.
    Figure : Open the exterior door
    Image: Open the exterior door
  3. Open the ink cartridge access door.
    The carriage moves to the center of the printer. Wait until the carriage is idle and silent before continuing.
    Figure : Open the ink cartridge access door
    Image: Open the ink cartridge access door
  4. Press down on the ink cartridge to release it, and then pull the ink cartridge out to remove it from its slot.
    Figure : Remove the ink cartridge
    Image: Remove the ink cartridge
       CAUTION:
    Do not touch the copper-colored contacts or the ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.
  5. Remove any protective tape that still might be on the nozzles.
       CAUTION:
    Do not try to remove the copper electrical strip.
    Figure : Remove the plastic tape
    Image: Remove the plastic tape and do not touch the contacts or ink nozzles
  6. Hold the ink cartridge by its sides with the nozzles toward the printer, and then insert the ink cartridge into its slot. Make sure that the ink cartridge is inserted in the correct slot.
    • The tri-color ink cartridge () goes in the slot on the left.
    • The black ink cartridge () goes in the slot on the right.
    Figure : Reinsert the ink cartridge
    Image: Snap the ink cartridge into place
  7. Push the ink cartridge forward into its slot until it snaps into place.
  8. Repeat these steps to replace the other ink cartridge, if necessary.
  9. Close the ink cartridge access door.
    Figure : Close the ink cartridge access door
    Image: Close the ink cartridge access door
  10. Close the exterior door.
    Figure : Close the exterior door
    Image: Close the exterior door
If the error persists, continue to the next step.
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
single-cartridge mode
The printer you own can work in single-cartridge mode, wherein the printer will be able to print with one cartridge in the printer.which will help us identify if its a cartridge issue or a printhead issue
To try single-cartridge mode follow the below steps:
remove the black ink from the printer, leave the color in and try printing
then remove the color ink and, insert the black  in and try printing
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Highlighted
Author
New member
2 1 0 0
Message 3 of 3
Flag Post
Thanks Jay for detailed instructions. Unfortunately, none worked and I have put the printer in repair shop.
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
