I am getting the "printer is out of paper" message, but it will print a configuration and demo page. This is a new issue—I have had this printer for several years.
2 REPLIES 2
If the device prints pages from the control panel with no problems then likely you have a size or type mismatch. Make sure that the paper size and type settings on the printer itself match the loaded paper and make sure that the print job you are sending is looking for that type of paper.
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
Here's a bit more information. My problem occurs when trying to print an 11X17 PDF color document. I get a printer error message saying, "printer is out of paper."
However, when I convert the file to an 11X17 tiff document, it prints.
I've used this printer for several years with similar pdf's.
