Windows 11 Support Center. -
- HP Community
- Printers
- HP 7602 tray LED light stays on
04-15-2025 04:11 AM
I do like the light. It has a nice aesthetic look. BUT, I would like to be able to turn it off or for it to turn off itself in sleep mode. It is distracting in my office configuration. I hope it can be changed by a software update unless it is already available?
Solved! Go to Solution.
04-16-2025 05:42 AM
Hi @LO46
Welcome to the HP Support Community!
Thanks for posting your query! We're here to help you get back up and running.
The tray LED light on the HP 7602 printer is indeed a stylish touch, but I understand how it can be distracting in certain setups.
Unfortunately, there doesn't seem to be an option to turn off the light or have it automatically turn off in sleep mode based on current settings or firmware updates.
You might want to check for any new firmware updates via the HP Smart app or the printer's settings menu, as HP occasionally releases updates that add features or improve functionality. However this feature isn't available yet.
If my response helped, please mark it as an Accepted Solution! ✅ It helps others and spreads support. 💙 Also, tapping "Yes" on "Was this reply helpful?" makes a big difference! Thanks! 😊
Take care, and have an amazing day!
Regards,
Hawks_Eye
04-16-2025 05:42 AM
Hi @LO46
Regards,
Hawks_Eye
04-21-2025 12:36 PM
A huge thank you for marking this post as the 'Accepted Solution'! We're thrilled that we could help resolve your issue.
If you have any more questions or need further assistance, please don't hesitate to ask. We're here to help!
Thanks again for your confirmation, and we wish you an amazing day ahead! 😊
Regards,
Hawks_Eye
