HP Color Laser MFP 178nw
Dear HP Community,
I am reaching out for assistance regarding my HP Color Laser MFP 178nw printer, which has been experiencing significant print quality issues over the past few weeks.
Issues Observed:
  1. Text Fading and Light Printing:
    • The text on printed documents appears faded and light in multiple areas, making it difficult to read.
    • There is inconsistency in print density, with some sections appearing much lighter than others.
  2. Blurry and Smudged Text:
    • The printed text is noticeably blurry, particularly in the lower half of the page.
    • Ink smudging is present, contributing to the unclear text.
  3. Misalignment:
    • The text seems misaligned.
  4. Inconsistent Print Quality:
    • Visible bands or streaks are appearing across the documents (issues with the toner or drum unit?).
I would greatly appreciate any advice or suggestions from the community on how to address these issues. If further diagnostics or specific maintenance procedures are recommended, please provide detailed instructions.
Thank you for your assistance.
Best regards,
1 REPLY 1
This is an example: ff.jpg
