×InformationHP Solution Center Adobe Flash player error
Please check this document to find the workaround solution for Print and Scan - HP Solution Center not working : Adobe Flash Player Error and Unable to scan
InformationFix Windows 10 Update IssuesResolve Windows 10 related issues for your HP computers or printers by HP Windows 10 Support Center
- HP Community
- Printers
- Re: HP Color Laser jet Pro MFP M281CDW- "Supply Problem"
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
11-24-2020 06:20 PM
BTW, forcing the use of OEM toner is a violation of US anti-trust laws. (See <https://wmpwebstore.com/products/your-rights-as-a-consumer/>) Instructions on how to report it are here: <https://www.justice.gov/atr/citizen-complaint-center>. I just reported it for my printer (HP Color LaserJet MFP M281fdw).
11-25-2020 10:57 AM
I have the same issue on an mfp 180nw printer. I get the Supply Problem in the printer display. I also have after market print cartridges, however, I also have HP print cartridges and put one in to see if the printer recognized and it did not. I mixed them up and the printer indicated the cartridges were in the wrong area and then returned to the supply problem when I put them back. This supply problem indicator happened after "programming" appeared on the printer display this morning. So whatever update was put through created the issue. I've updated the firmware and it is not working. I can't find the previous drivers to try downgrading it. Please let me know if you have any suggestions.
11-25-2020 11:35 AM
I see HP has removed the link here, and removed the software from their servers. I'll try to do this in a way that won't get it automatically removed... Go to reddit.com and search for "HP LaserJet Pro M280 M281 Printer series 20200612 firmware downgrade". The result you're looking for is in r/printers, posted by u/Tony707. It wasn't working for me over wifi, but it worked fine over a usb connection. Note that this firmware will not work on a 180 series printer, but I presume the instructions about enabling/disabling updates still apply. If you search for "ghost-white-toner" on that page, you should find a link that covers more printers.
11-27-2020 09:20 AM
Hello @teebee412 ,
Could you confirm if the error is "Error 79" or its "Error 79 " accompanied with Supply Error ?
Jabzi
Give Kudos to say "thanks" by clicking on the "thumps Up icon" .
Click "Accept as Solution" if it solved your problem, so others can find it.
Although I am an HP employee, I am speaking for myself and not for HP.
Didn't find what you were looking for? Ask the community
