Received an error message, and it went black.  Now HP OfficeJet 4650 printer won't power on.
1 REPLY 1
Hi @wisconsiner ,
Welcome to The HP Support Community.
I understand your HP OfficeJet 4650 printer won't power on after displaying an error message and going black, there could be several possible causes for this issue.
May I know if any lights are blinking on the printer
Here are some steps you can try to troubleshoot the problem:
  • Check Power Connection: Ensure that the power cable is securely connected to both the printer and a working power outlet. Try plugging the printer into a different outlet to rule out any issues with the power source.
  • Power Cycle: Disconnect the power cable from the printer and wait for about 30 seconds. Then, reconnect the power cable and try turning on the printer again.
  • Check Power Adapter: If your printer uses an external power adapter, check to make sure it's not damaged. If possible, try using a different power adapter that matches the specifications of your printer.
  • Reset Printer: Some printers have a reset button or sequence that can help resolve issues. Check the user manual for instructions on how to perform a reset on your specific printer model.
  • Remove External Devices: Disconnect any external devices such as USB drives or memory cards from the printer and try powering it on again.
  • Inspect for Physical Damage: Carefully inspect the printer for any signs of physical damage, such as frayed cables or loose parts. If you find any damage, it may need to be repaired or replaced.
Refer to this document: HP OfficeJet 4650 All-in-One Printer series user manual
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution.
A_Gayathri
HP Support Community Administrator.
