×InformationHP Solution Center Adobe Flash player error
Please check this document to find the workaround solution for Print and Scan - HP Solution Center not working : Adobe Flash Player Error and Unable to scan
InformationFix Windows 10 Update IssuesResolve Windows 10 or update issues on HP computer or printer– Click Here
- HP Community
- Printers
- HP OfficeJet 8600 Plus power light blinking and unresponsive
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
01-13-2021 01:59 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
The power light blinks and printer is unresponsive. Turn off and back on and it works but reoccurs after awhile. I saw earlier posts suggesting hard reset; may I have the instructions for semi hard reset ? Using MacOS 11.1. Thank you.
01-17-2021 02:34 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
I reviewed your post and I understand that the printer is not responding sometimes.
Don’t worry, I assure you I will try my best to get this sorted.
I recommend you follow the below steps and check if it helps.
Here is how you can get in touch with support.
1)Click on this link – www.hp.com/contacthp/
2)Select the product type.
3)Enter the serial number of your device or select let HP detect your product option.
4)Select the country from the drop-down.
5)You should see the HP phone support number or Chat option listed.
If you continue facing the issue, then follow the steps in the below article and update the printer firmware.
https://support.hp.com/us-en/document/c02919168
Let me know how it goes and you have a great day!
P.S: Welcome to the HP Support Community 😊
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
Stay Home – Stay Safe
The_Fossette
I am an HP Employee
01-20-2021 12:42 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
Hello, thanks for getting back to me. This did not work, at least not with the HP Smart app. When I open the printer in HP Smart app, it reads the printer status as "Unavailable" under the Status area, but under the Printer Information area it says status is "Ready." When I click on Advanced Settings I get an error message that simply says "Can't open printer home or EWS page. This feature is not available." It does not seem like the HP Smart app is really communicating with my printer.
In the end, I updated the firmware from the HP webpage and will see if that helps with the problem I have been experiencing.
Didn't find what you were looking for? Ask the community
