cancel
Showing results for
Search instead for
Did you mean:
    Fix HP Printer issue in macOS
    A [software component] will damage your computer message displays when printing or while installing - Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Note for common printer problems
Customers receiving the"will damage your computer" message along with others like "unable to access cups/tmp" or "'@%' cannot be opened" need to update their version of the macOS. Please check this article for more information: HP Printers - A [software component] will damage your computer message displays when printing or while installing (macOS) .
Highlighted
New member
1 0 0 0
Message 1 of 2
92
Flag Post
Solved!
HP OfficeJet Pro 8710 wireless configuration issue
Please help with instruction to correct.
I am trying to connect my printer to a network for internet connection.
However, I am receiving an error message;
This feature has been disabled. Contact the person who set up the printer.
I tried reset, factory reset, will receiving same message.
Microsoft Windows 10(64-bit)
Thank you
[Private information removed]
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
15,250 15,228 1,196 1,193
Message 2 of 2
Flag Post
@Kat13003, Welcome to HP Support Community!
The only option left is to perform a full reset and re-initialize the printer.
The reset instructions are specific for your printer and performing those steps on a different printer may brick the device.
I've sent you a private message with reset instructions, follow the reset instruction to perform a full reset and re-initialize the printer.
In order to access your private messages, click the private message icon on the upper right corner of your HP Forums profile, next to your profile Name or simply click on this link.
Hope this helps!
TEJ1602
I am an HP Employee
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
