×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Printers
- HP OfficeJet Pro 8710 wireless configuration issue
08-18-2020 06:54 PM - last edited on 08-19-2020 07:23 AM by MatheusH
Please help with instruction to correct.
I am trying to connect my printer to a network for internet connection.
However, I am receiving an error message;
This feature has been disabled. Contact the person who set up the printer.
I tried reset, factory reset, will receiving same message.
Microsoft Windows 10(64-bit)
Thank you
[Private information removed]
Solved! Go to Solution.
08-21-2020 08:05 AM
@Kat13003, Welcome to HP Support Community!
The only option left is to perform a full reset and re-initialize the printer.
The reset instructions are specific for your printer and performing those steps on a different printer may brick the device.
I've sent you a private message with reset instructions, follow the reset instruction to perform a full reset and re-initialize the printer.
In order to access your private messages, click the private message icon on the upper right corner of your HP Forums profile, next to your profile Name or simply click on this link.
Hope this helps!
TEJ1602
I am an HP Employee
08-21-2020 08:05 AM
Hope this helps!
TEJ1602
I am an HP Employee
Didn't find what you were looking for? Ask the community
