cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
1 0 0 0
Message 1 of 2
51
Flag Post
HP Officejet 8620 problem with the printer or ink system.
HP Officejet Pro 8620
I changed the Cyan cartridge and got a printer failure. "There is a problem with the printer or ink system. Turn printer off, then on. If problem persists, contact HP". I have taken out the cartridges and cleaned them. I checked the print heads for spilled ink. I have shut down and restarted printer and computer several times. I have unplugged and reset several times. I was looking on the message boards and it seems it is a common problem and those who are out of warranty should upgrade the printer. I'm just looking to see if there is any way to fix this. Any ideas would be helpful.
Thank you!
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
5,675 5,646 337 377
Message 2 of 2
Flag Post
Hi @ChristineD103
If you have already performed the steps from the document  Resolving 'Ink System Failure', 'System Supply Problem' Errors and the issue persists, it could be a hardware failure.
Please reach out to the HP Support in your region regarding the service options for your printer.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile Name, you should see a little blue envelope, please click on it.
Hope this helps!
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
