HP SMART TANK 520,    SL. NO.  [edited],    PRINTER HEAD PROBLEM - UNABLE TO PRINT AT ALL - A  PROBLEM WITH THE COLOR PRINT HEAD (3 DOTS)
1 REPLY 1
Hello @abcd1234893191 , how are you ?
Please, try the procedures below:
Printhead errors on HP Smart Tank 210, 520, 540, 580, 590, or 5100 printers | HP® Support
Best regards
Welcome to the Community, I am a volunteer and private messages will not be answered.
If the answer was helpful and/or you would like to say "thanks", Click on the button“Yes” Did I help solve the problem? Don't forget click “Accept as a solution” , If anyone has the same question, this solution might be helpful.
