HP Smart Tank 518 Wireless All-in-One
My HP Ink Tank 518 Printer is showing only Resume Button Red Light and Screen Redlight no power button light. what is the solution?
2 REPLIES 2
@abirhasan-iut, Welcome to HP Support Community.
Based on your description and the image you provided, your HP Smart Tank 518 Wireless All-in-One Printer is showing:
  • A red Resume button light (paper icon)
  • A red screen light
  • No power button light
These indicators typically point to a hardware or operational error. Here's how you can troubleshoot this step-by-step:
Check for Paper Jam or Out of Paper
  • Open the input and output trays.
  • Remove any jammed paper carefully.
  • Ensure the paper is loaded correctly in the input tray.
Check Ink Levels and Cartridges
  • Open the ink tank lid and ensure all ink tanks have sufficient ink.
  • Make sure the ink tank caps are properly closed.
  • If recently refilled, ensure no air bubbles are trapped in the ink lines.
Reset the Printer
  • Disconnect the power cable from the printer and wall outlet.
  • Wait 30 seconds.
  • Reconnect the power cable directly to a wall outlet (avoid surge protectors).
  • Press the Power button to turn on the printer.
Check for Printhead Issues
  • Open the front access door and inspect the printhead area.
  • Make sure the printhead is properly seated.
  • Use the HP Smart App or printer menu to run a printhead cleaning.
Firmware Update (if accessible)
If the printer powers on after reset, check for firmware updates via the HP Smart App or HP Software and Drivers.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
