HP Smart Tank 6001 All-in-One
Printer worked fine. I had a power outage and now my Printer won't power on. I've tried all of the trouble shooting tips I can find. Please help!
1 REPLY 1
@SaraB70, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
  • Ensure the power outlet is working by testing it with another device. Try a different outlet just in case.
  • If the printer was plugged into a surge protector or power strip, plug it directly into the wall outlet.
  • Perform a Hard Reset
    • Unplug the power cord from both the printer and the wall.
    • Hold the power button on the printer for 30 seconds to drain any residual charge.
    • Wait 2-3 minutes, then plug the power cord back into the wall first, then the printer.
  • Look for any damage or loose connections. If you have another compatible power adapter, try using it.
  • If absolutely nothing works, the internal power supply might have been damaged by the outage, and it may need repair or replacement.
I hope these steps help resolve the issue
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
If my response helped you or made things easier, I’d truly appreciate it if you could mark it as an Accepted Solution This not only helps others find the right fix faster but also spreads the support. 💙 And if you found my reply helpful, tapping "Yes" on "Was this reply helpful?" means the world- it ensures more people get the solution they need! 🌟 Your small action can make a big impact! 💪😊
Regards,
Garp_Senchau
I am an HP Employee
