×InformationNeed Windows 11 help?Check documents and videos on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
- HP Community
- Printers
- HP officejet pro 8020 with blue screen and power icon and 04...
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
HP officejet pro 8020 with blue screen and power icon and 04358A98 error code
01-18-2022 08:53 AM
I have a HP officejet pro with blue screen. Power symbol and 04358A98 error code.
01-21-2022 03:12 PM
Thank you for posting on the HP Support Community.
Don't worry as I'll be glad to help,
I understand you are receiving a "04358A98 " error on the printer screen. We can perform a factory defaults on the printer to resolve the issue
- The reset instructions are specific for your printer and performing those steps on a different printer may corrupt the device.
- I've sent you a private message with reset instructions, follow the reset instruction to perform a full reset and re-initialize the printer.
- In order to access your private messages, click the private message icon on the upper right corner of your HP Support Community profile, next to your profile Name or simply click on this link: https://h30434.www3.hp.com/t5/notes/privatenotespage
Hope this helps! Keep me posted for further assistance.
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping!
ECHO_LAKE
I am an HP Employee
01-25-2022 02:39 PM
ECHO_LAKE
I am an HP Employee
01-28-2022 08:17 AM
Hello Echo Lake,
I have the same problem. I have read your reply but I cannot find the private message icon to click to ask for the instructions for the solution. Where can I find it please? Thanks Frederica
01-29-2022 10:06 AM
ECHO_LAKE
I am an HP Employee
01-29-2022 03:29 PM
3 times today the display screen for HP officejet 8020 series flashes furiously and the ONLY way to stop it is to unplug the printer then plug it back in. Most recently I got the blue screen with power icon and error code (04 something....) so I unplugged and plugged it back in. Okay for now. Why is it doing this?
Didn't find what you were looking for? Ask the community
