cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
1 0 0 0
Message 1 of 2
61
Flag Post
HP officer pro 8610 print head issue
HP officer pro 8610
Microsoft Windows 10 (32-bit)
After following the steps to reset printer because of yellow cartridge issue, the print head stopped moving
1 REPLY 1
Highlighted
HP Support Agent
HP Support Agent
5,714 5,685 339 379
Message 2 of 2
Flag Post
Hi @Anthonyzm,
I'd like to help!
Try the below suggested steps -
Step 1: Check for obstructions in the carriage path
Make sure the carriage path is not blocked.
  1. With the printer on, disconnect the power cord from the rear of the printer.
  2. If your printer has a battery, remove the battery.
  3. Open the door to access the carriage inside of the printer.
    Examples of carriage access doors
    Opening an access door on top of the printerOpening an access door on the front of the printer
  4. Look in the carriage path for debris such as crumpled paper or dislodged labels, and then remove any that you find.
    Example of a printer with debris in the carriage path
    View inside a printer showing crumpled paper in the carriage path causing a carriage jam
  5. If the carriage on your printer has a latch, make sure it is closed.
       CAUTION:
    Ink tank printers: If the latch is closed, do not press down on it.
    If the printhead latch is closed, do not press down on it
  6. Use your hand to move the carriage to each side, making sure it moves freely. If the carriage is stalled or docked to one side of the printer and you cannot move it, continue with these steps.
  7. Close the carriage access door.
  8. Reconnect the power cord to the rear of the printer, and then turn the printer on.
If the error persists, continue to the next step.
Step 2: Reset the printer
An error might continue to display after the jam is cleared. To clear the error state, reset the printer, connecting the power cord directly to a wall outlet to make sure the power source is stable and prevent more carriage jams.
  1. With the printer turned on, disconnect the power cord from the printer.
  2. Unplug the power cord from the power source.
  3. Wait 60 seconds.
  4. Reconnect the power cord to a wall outlet and to the printer.
    NOTE:
    HP recommends plugging the printer directly into a wall outlet.
    If the issue persists, I'd suggest you Contact HP in your region regarding the service options for your printer
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
Reply
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
