HP4635 officer cannot turn on after power outage.
1 REPLY 1
Hi @Barb196 ,
Welcome to The HP Support Community.
I understand you are facing an issue with your HP Officejet 4635 e-All-in-One Printer will not power on after a power outage, the issue might be related to the power supply or internal electrical components. Here's a step-by-step guide to troubleshoot and possibly resolve the issue:
1. Check the Power Source:
  • Ensure the wall outlet is working:
    • Plug another device (like a lamp or phone charger) into the same outlet to verify it has power.
    • If the outlet is not working, try resetting your circuit breaker or using a different outlet.
2. Inspect the Power Cord and Adapter:
  • Look for visible damage (frayed wires, burnt marks) on the power cord or adapter.
  • If damaged, replace it with an HP-compatible power cord.
3. Perform a Hard Reset:
  • Disconnect the printer's power cord from the printer and the wall outlet.
  • Wait 2–3 minutes to allow any residual charge to dissipate.
  • Reconnect the power cord securely to both the printer and the wall outlet.
  • Press the Power button to try turning it on.
4. Test with a Direct Connection:
  • Avoid using power strips, surge protectors, or extension cords.
  • Plug the printer directly into a wall outlet, as power strips can sometimes block sufficient voltage after a surge.
5. Check for LED or Button Activity:
  • Observe the power button or any lights on the printer:
    • If there's no response at all, it might indicate a power supply or internal hardware issue.
6. Try a Different Power Cord or Adapter:
  • If you have another HP printer with a similar power cord or adapter, test using that to rule out a faulty power supply.
7. Perform a Factory Reset (if the printer powers on briefly):
  • If the printer shows signs of life but doesn't fully power up, you may need to perform a factory reset. Let me know if it powers on temporarily, and I can guide you through the reset process.
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos/Thumbs Up" on the bottom right to say “Thanks” for helping!
Gaya1239 – HP Support.
