×InformationHP Solution Center Adobe Flash player error
Please check this document to find the workaround solution for Print and Scan - HP Solution Center not working : Adobe Flash Player Error and Unable to scan
InformationFix Windows 10 Update IssuesResolve Windows 10 or update issues on HP computer or printer– Click Here
- HP Community
- Printers
- Help Please !!! LaserJet Pro MFP148 FDW - won't print, error...
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
Help Please !!! LaserJet Pro MFP148 FDW - won't print, error message= "go to notifications settings"
12-22-2020 06:40 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
I just bought this $200 printer a month ago. Only used it for some scanning, now it won't print, the printer was turned on with paper and connected. I would greatly appreciate some help from some techie out there!! Thanks!!
The error message says "go to notification settings" - then "turn off all notifications for Print Notification"
Tried unsuccessfully to find this in the chat and other places with no luck and got super frustrated.
Thank you for any help!! 🙂
01-05-2021 10:59 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
@ValleyGal-19, Welcome to HP Support Community!
Follow the steps below to isolate and resolve the issue-
Use HP Print and Scan Doctor
Download HP Print and Scan Doctor and run the program. It will automatically diagnose and fix any printer connectivity issues.
For more information, go to https://support.hp.com/us-en/topic/printscandoctor
I recommend you delete the driver and root level and retry, follow the steps below:
1) In Windows, search for and open Programs and features
2) Select your HP Printer
3) Select Uninstall
4) In Windows, search for and open Devices and printers
5) In the Devices and Printers windows look for your HP printer. If you see it listed right-click on it and choose ‘Delete’ or ‘Remove Device’
6) Open up the run command with the “Windows key + R” key combo.
7) Type printui.exe /s and click Ok. (Note: there is a space in between “printui.exe”
😎 Click on the “Drivers” tab
9) Look for HP Printer driver. If you see it Click on it and click Remove at the bottom
10) Select Ok
11) Select Apply and Ok on the Print Server Properties windows
12) Close Devices and Printers.
Use this link to download and install the new driver. Configure the printer and try printing.
TEJ1602
I am an HP Employee
01-05-2021 07:31 PM
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Flag Post
Thanks so much, TEJ.... I am not sure what happened that day, it wouldn't print. Amazingly, I used it another day after that and it worked.. I will save your feedback in case it happens again. Appreciate your help!!! 🙂
Sincerely,
VG
Didn't find what you were looking for? Ask the community
